2018 Tundra LED headlight wiring info with diagrams
Discussion in 'Lighting' started by thomasbus337, Sep 6, 2017.
  1. Sep 16, 2017 at 9:14 PM
    #91
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    Where did you get the headlights form? I ordered mine and am still waiting on them to show up.
    4x4_Angel likes this.
  2. Sep 16, 2017 at 9:18 PM
    #92
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    i won't order until i can plug and play...I HATE having to wire crap
  3. Sep 16, 2017 at 9:34 PM
    #93
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    It is safe to assume we are there as far as PNP goes with the work @thomasbus337 has done. I am sure he will put some together for those who want for a fee ofcourse. I am waiting on the lights and the OEM connectors and it is a go. @st33l did you use the motocontrol harness or do it with out?
  4. Sep 16, 2017 at 9:46 PM
    #94
    st33l
    st33l New Member
    2014 Tundra MGM Platinum
    @pvdubber i used the motocontrol harness.
    pvdubber likes this.
  5. Sep 16, 2017 at 9:48 PM
    #95
    4x4_Angel
    Bree
    Funky Town, Texas
    I don't honestly know. ...i do know i want them and everything to be plug and play
  6. Sep 16, 2017 at 9:49 PM
    #96
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    Thanks, Where did you get the headlights form?
  7. Sep 16, 2017 at 9:53 PM
    #97
    st33l
    st33l New Member
    Ordered the headlights from @Roman about 3 weeks ago.
  8. Sep 16, 2017 at 10:01 PM
    #98
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Did the headlights come with the signal bulb? And did you swap the pins on the harness?
  9. Sep 16, 2017 at 10:10 PM
    #99
    st33l
    st33l New Member
    Headlights came with bulbs and i did have to switch the pins on the turn signal harness from 2 to 1. Switching the pins out was a lot easier than I thought it was going to be.
    BlueBottle likes this.
  10. Sep 17, 2017 at 6:35 AM
    #100
    iHacker
    iHacker SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Looks great man this is changing my mind and probably will swap my retros with this in the future.
  11. Sep 17, 2017 at 6:48 AM
    #101
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    @st33l Nice work ... looks great! How much did you say you were selling the plug and play harnesses for? ;-)
    texbambam likes this.
  12. Sep 17, 2017 at 7:02 AM
    #102
    st33l
    st33l New Member
    @thomasbus337 deserves all the credit here and for showing us how to do it. I wouldn't start making harnesses to sell them over him.
    If you're on the fence about having to fab this harness, don't be. I have never done any wiring before and I was able to do this. As long as you get the parts and follow the wiring diagram that @thomasbus337 provided, you guys should be good to go.
  13. Sep 17, 2017 at 7:10 AM
    #103
    TuffTundra
    TuffTundra New Member
    Missouri
    2016 MGM SR5
    4" Rough Country Lift - Fuel Assault 20x10 - Nitto Ridge Grapplers 33x12.5x20 - 2018 LED Headlights - LED Lights all around - No Chrome - Tinted Windows & Tail Lights
    Guess I'm more of a visual guy that I would like to SEE it put together...rather than looking at a diagram. For me diagrams can get confusing as to how everything gets put together. I have no doubt that if I saw a video of someone putting this thing together I could do it myself. I just want to make sure I put together a harness that will work with my '16 SR5 that only had the inner orange DRL. Hope one of you guys can put out a video for us to view.
    etxdude, 757TUNDRA and Tophergt99 like this.
  14. Sep 17, 2017 at 11:48 AM
    #104
    thomasbus337
    thomasbus337 [OP] New Member
    2020 TRD Sport DC
    I’m happy that it worked for you, they sure do class up the front end of the truck.
    If someone else wants to use my recipe to make these harnesses for sale, you have my blessings. I’m still waiting on a few more parts to come in, then I’ll have a pictorial” how-to” PnP add-on for LED DRL on SR, SR5, Limited and Pro models. At that point, I will have (3) PnP Platinum/1794 harness sets and (2) SR, SR5, Limited and Pro sets for sale on eBay. The SR, SR5, Limited and Pro will have more parts so the price will be higher. These harnesses are easy to make, it’s just a bit costly and time consuming to round up all the parts to put them together so it’s not something I want to keep doing.
    Tundra_Dawg, PROTX, kkim124 and 8 others like this.
  15. Sep 17, 2017 at 12:10 PM
    #105
    thomasbus337
    2020 TRD Sport DC
    I put together a small parts list to make a hi beam relay harness to upgrade the high beam wiring from 20awg wiring on the Morimoto H4 motocontrol harness to 16awg with this add on harness. I found a Hella relay that has (2)-87 output pins to help simplify the wiring. I used the original 9006 “high beam” female output plug on the moto harness for the ground and trigger for the relay. I grabbed power off the battery with a in line fuse holder. Lastly, I ran 16awg off of each 87 pin to the high beam input on the headlight plug. I used a 9006 male plug with 2 cavity plugs inserted to cap off the moto “high beam” plug on the pass side.
    Parts for upgraded Hi Beam headlight relay
    1-5-pin SPST Double 87 Pin Relay – Hella HLA-933791091 www.summitracing.com
    1-Hella 5 pin relay socket – H84989021 Ebay/Amazon
    5- Hella 6.3mm terminal with catch – Hella 701235033 www.amazon.com
    1-Bussmann 16g fuse holder and 10amp fuse
    2-Delphi 9006 Male 2-pin Plug CONN- 75893
    2- Delphi 9006 Female 2 pin plug CONN-75669
    4- Delphi weatherpack cavity plug – 12010300
    Relay Diagram
    85-Ground terminal from “High Beam” plug on motocontrol harness
    86- Power terminal from “High Beam” plug on motocontrol harness
    30- Fused battery power
    87- Relay output to High beam
    texbambam, 1UPPER, BlueBottle and 7 others like this.
  16. Sep 17, 2017 at 12:47 PM
    #106
    jdm ctr '00
    jdm ctr '00 New Member
    los Angeles, CA
    2016 Tundra TRD PRO
    That looks fantastic, Great job :thumbsup:. I hope to see a how to for my Pro also.
  17. Sep 17, 2017 at 1:52 PM
    #107
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    @thomasbus337 do you have the link to eBay for the platinum harness? I would like to buy one.
    kkim124 and 757TUNDRA like this.
  18. Sep 17, 2017 at 7:33 PM
    #108
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    Damn that looks gangster! Great job OP.
  19. Sep 17, 2017 at 11:40 PM
    #109
    uaeboy
    uaeboy New Member
    mubarak
    2017 Toyota Tundra
    @thomasbus337 do you have the link to eBay for the 1794 harness? I would like to buy one.
  20. Sep 18, 2017 at 6:08 AM
    #110
    sartod01
    sartod01 New Member
    2017 Black 1794
    I'm in as well!! Link to ebay 1794 harness???
  21. Sep 18, 2017 at 12:04 PM
    #111
    kkim124
    kkim124 New Member
    Torrance, CA
    2016 Tundra Platunum 4x4
    A link for the platinum harness in the ebay store please.
  22. Sep 18, 2017 at 3:50 PM
    #112
    Snow
    Snow New Member
    2017 MGM Tundra SR5 TRD
  23. Sep 18, 2017 at 4:36 PM
    #113
    thomasbus337
    2020 TRD Sport DC
    No ebay links yet. I'm still waiting on a bunch of the 8pin plugs and a few other parts to come in. Just so no one will be surprised, the 1794/Platinum model harnesses have about $60 worth of parts put into them and the other models even more. I'm not trying to get rich off of these, trying to break even with what I have put into them.
  24. Sep 18, 2017 at 4:48 PM
    #114
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    2015 Platinum Crewmax
    D.A.P. Tune Bilstien 6112/5160 33x12.50xr20 Toyo Open Country M/T 20x9 Fuel Coupler TRD Exhaust
    I am open for whatever that price is, your time that you have put into it counts. I am good with you make money on these. When they are ready I have my card ready. Thank you sir.
  25. Sep 18, 2017 at 4:57 PM
    #115
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    Don't sell yourself short on your time and investment, time is money so no matter the price people will pay, including myself lol thanks for figuring the wiring out, I pulled the trigger on the headlights today lol
    AK-in-MI and 757TUNDRA like this.
  26. Sep 18, 2017 at 5:02 PM
    #116
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I ordered all the items you listed and it came to $140+. Did I ordered more than I needed? Gonna. Hulu my harness this week. It's for a platinum.
    757TUNDRA likes this.
  27. Sep 18, 2017 at 5:06 PM
    #117
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    I pulled the trigger as well and ordered the headlights today.
    Tundracollector likes this.
  28. Sep 18, 2017 at 5:11 PM
    #118
    thomasbus337
    2020 TRD Sport DC
    I was rounding numbers and I didn't include S&H or the cost of the Morimoto relay harness. I also found another source for the Delphi 9006 male plugs and related Delphi parts which brought the price for those parts down a little bit.
    BlueBottle[QUOTED] likes this.
  29. Sep 18, 2017 at 5:15 PM
    #119
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I'm just waiting on the crimping tool. I have everything else.
  30. Sep 18, 2017 at 5:40 PM
    #120
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Kool.. I'm ready to order! Can't wait..
