2006 tundra Access Cab, wiring in aftermarket radio cannot find wiring color code schematic
Discussion in '1st Gen Tundras (2000-2006)' started by tom723, Dec 17, 2017.
  1. Dec 17, 2017 at 2:22 PM
    tom723
    tom723 [OP] New Member
    Tom
    2006 Tundra SR-5 Access Cab
    I'm wiring in an aftermarket head unit in my 2006 Access Cab Tundra. The stock radio is not JBL /Fujitsu. Every color code schematic that I have looked at on the web matches up but for a handful of wires. After throwing away over $60 dollars in harness adapters that do not fit, I cut the harnesses off that went to the stock radio have all the new wires connected except for the speaker wires. I need HELP!!! Tired of riding with no stereo in the dash! I attached the wiring diagram I used but there are a couple of the speaker wire colors that don't match up. So far my new head unit powers on with ignition and illumination lights working, functions but no sound due to not knowing the right oem color code for the speakers.
  2. Dec 17, 2017 at 3:33 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    All the charts I've seen show similar colors. The sure fire way to figure it out is to use a meter and test from each speaker.
    tom723[OP] likes this.
  3. Dec 17, 2017 at 4:16 PM
    tom723
    Tom
    ok, I will give that a try...will see what happens!
  4. Dec 18, 2017 at 6:36 AM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    The speaker wires are located at the factory amp under the rear passengers seat. It is signal wires at the dash location and will not give you any sound you must now bypass the amplifier and run speaker wires up to the dash.
